LSPV?
There is a rubber bulb-like thing on the driver's side in front of the rear axle...what is this? Mine is leaking. Should it have a clamp on the hard line coming from it going toward the rear? Mine doesn't. The rubber bulb feels like it is full of fluid. What the hell is this thing?
Thanks,
Chris
the rubber thing it's just a dust cover .. it's leaking from the inside .. replace it
main.php
Mine is leaking after sitting overnight on the rack with suspension at full droop. Guess it is time for a rebuild/new one. Guess I will replace both calipers and all three hoses while I am at it.
I think you have the record w/a 7 yo thread resurrection! :clap:
Yes, new one. Not rebuild-able (Per CDan when I replaced mine).
Thanks flintknapper. Looks like you purchased the bleeder screw assembly as well. They are a little higher than that now. I am waiting on mine to come in now.
I am sure they are like a billion dollars now /s.
What is a good reason not to delete it? I deleted all of my ABS and my LSVP and just tried out my brakes this evening on fresh snow. I can lock up all four with very little effort. I do have new pads and calipers and new front rotors.
$159.86.
No good reason other than I like OEM.
