- Joined
- Dec 17, 2006
- Threads
- 63
- Messages
- 886
- Location
- Central Coast, CA
- Website
- www.coastal-aquariums.com
Did a front brake overhaul last week. Started with just doing pads, but then realized it was time to change rotors and ended up needing a new caliper as well. While I was in there I changed wheel bearings on DS and repacked the ones I changed a few years ago on PS.
I never adjusted my LSPV after I lifted a few years back so I decided to do that before bleeding all of the brakes. Adjustment went well, gotta love being in CA where rust isnt really an issue, the bolts popped loose on first try and it was a 1 minute "fix".
Now for the question: When I went to move the LSPV, I kind of squeezed the rubber boot on the LSPV and some fluid came out of it. My first thought was brake fluid, but a mechanic friend of mine said no brake fluid should be able to come out of there and that maybe it was water? On a side note, the rear calipers wouldn't really bleed any fluid, just a touch of foam at the begining (like1/2" in the clear tubing that I used to bleed brakes), never really releasing a quantity of brake fluid like the fronts did. The LSPV bled fine and the brakes definitely work better after the brake job than before (that's not saying a whole lot because they were getting scary before the brake job). I do plan on bleeding all 5 spots again soon, hopefully next weekend to check if the rears will bleed with a second attempt.
So, anyt thoughts on the fluid that came out of the LSPV boot or the rear brakes that wouldn't bleed?
Thanks in advance. The picture isn't there to help answer the questions, but rather because I like to see my work
