LSPV for 91
Alright, I have been searching all last night and today on LSPV deletes and found a ton of info, but it’s mostly for 93+ FzJ80s. My Google fu is not the best, so I will happily eat crow if someone can show me thread that has what I need.
I am looking at deleting the LSPV as it is leaking pretty bad. But all the threads seem to only cover the wrong years. I have a 91 with no ABS. There are 4 connections, I get that one will be deleted (the one that attaches tot eh rear axle) but how does the T get the others to hook up? It’s seems like the lines are all positioned wrong. How do you bend the lines with out kinking the brake line?
While I’m at it, is the rebuild kit worth it? Has anyone done it and had no issues? I am debating putting in a manual valve by the booster like JCardona.
pics could help. I'm guessing that theres 2 lines coming from the master, one is the pressure line and the other the return line for the bypass. and I'm also guessing that the other two are going to each wheel.
I used the t fitting when I deleted mine, one line from the master, one going back to the abs actuator and the third line going to the brakes on the rear axle.
Man why not just replace it, it's not that hard as long as you don't bugger up the long brake lines coming from the front. I did it, and I am certainly no mechanic. I don't know you, but I'll guarantee you that if I can do it, you will do it 5 times better! :beer: But I find that desire to learn and do things for myself can often compensate for lack of experience, and you have Mud for the knowledge! It's a safety feature on the most important safety system on the truck. I know lots of guys are pretty cavalier about deleting LSPV, but I'm not so sure it's a great idea, and you do assume some liability by doing it. I bought the new valve with boot and screw kit, not that expensive. Plus, getting the job done will give you the experience and confidence to maybe tackle something a little bigger next time. To me this is what owning an old vehicle is all about. Good luck.
I had been having a difficult time bleeding my brakes for a while. They always seemed a bit too mushy. Recently I noticed a bit of fluid dripping out of the LSPV so ordered a cheap brand new valve off E Bay. Replacement was simple. I deleted the "load sensor" while I was replacing the valve. Brakes are now solid and have never worked better. LSPB valve or Wilwood proportioning valve?
So I have a spare parts cruiser in my garage and pulled the LSPV off of that one. It looked better than the one that came off my cruiser that was leakin. But it still looked like it would leak, the top of the piston looks like it would not seal due to corrosion. I took the t on the brake booster off of the spare parts cruiser and deleted the lspv off of my dd. That was a mistake. I guess I can drive it now, but I can lock the breaks up just by pressing not even that hard on the pedal. The rears lock up first and the pedal goes all the way to the floor. I guess there is some air in there still. I didn’t really want to delete the lspv because but had no choice as I need to drive it for work. So now I am looking at replacing with a new unit ($$), rebuilding, or a manual valve. I like the idea of the LSPV and would rather do that than a manual. I like the auto adjust. A manual would require me to get a flare tool on top of the cost of a manual valve.
Do you have that part number? What all was included with that part number? From what I have read on mud, i thought there was no rebuild kit. How much was the rebuild kit?
I ordered from Toyota Parts Overstock/Lakeland Toyota; I believe beno was out of pocket at the time:
1991 TOYOTA LAND CRUISER BRAKE TUBE & CLAMP
I ordered the valve #47910 on the diagram, bush and boot kit #04477, and the mounting plate, #47937 (I had to saw mine off).
Good luck!
Hell. I'm just never quite sure if I can trust vendors on eBay, Amazon getting about the same.
As far as I know, yes. I think I remember running across a YouTube video where a guy took his apart and cleaned it up and got it back working but I cannot find it now. Worth trying I guess if you have the time and like to tinker. I would be prepared to buy a new one!
