LSPV Adjustment?
Hmm.... I think I may have missed a step somewhere. I just recently put an OME 2.5" med (shocks and springs) on. Asked questions about the procedure, etc to install. No note i recall on the LSVP. I Did not adjust my LSVP.
Did I miss something? Right topic right? Havent noticed anything super different in braking, just figured the lift would behave a little different do to spring and shocks which I can notice (very very small). But not enough to make wonder too hard.
Should I be looking into this as well?
The reason the LSPV needs adjusting after a suspension mod is that the static distance between the frame and the rear axle has changed. Usually, in our case, increased because we are raising our vehicles. If this is not readjusted, the LSPV is fooled into thinking that the rig is running constantly lighter than normal. This biases braking force more to the front brakes and wears them out even quicker than the 80s short life of approx. 15k. Now, normally, most guys who are naive (no offense intended) wouldn't notice this even in the performance area, except for abnormally fast wear on front brake pads. So the error is in your favor, performance wise, if no LSPV adjustment is done. Just faster front brake pad wear.
OK here is a question , Does it work this way 70% front 30% rear empty. And loaded 60% front 40% rear? So you always have a 100% braking?
OR this way 70% front and 20% rear empty. And loaded 70% front and then its adds more to the rear up to 30% or more ??
Here is my thinking , If it only limits the rear when empty but reducing the rear brake effort then I would say adding a little more rear braking would give you more stopping power in ideal conditions.
But I'm sure Toyota has it set for less then ideal conditions like rain or snow for your average driver.
But that can be over come by just pushing a little harder on the brake until you reach 100% and then you may wish you had more rear.
Here is a other question is the ABS separated front and rear so if the rear starts to lock do you still have 100% non ABS on the fronts until they start to lock up?
Brian
4x4ing in Cambodia
Brian
4x4ing in Cambodia
Brian, I don't know the percentages, maybe some Toyota engineer could chime in. It looks like you've got the concept, though. As far as the ABS - each wheel has it's own sensor that watches for wheel lockup on that wheel only. The ABS ECU, when ABS is activated (CDL NOT engaged), is responsible for controlling the braking power supplied to each wheel. So if any wheel starts to lock up, that sensor tells ECU and ECU signals ABS Actuator to pulse braking on that wheel. Now this is if the system is working. Most of our 80s are 10 years old and older. I have seen some threads of owners complaining about their ABS malfunctioning - you might want to do a search on ABS on this forum for some more info. HTH
There was just a thread within last few weeks on ABS. Seemed like the front ABS was independent and the rear was a single sensor split to the rears. Could have miss read that. But quick search on ABS should answer the rest.
I read that thread, too. My FSM doesn't really confirm or deny that. It shows 4 independent wheel sensors and one actuator for all 4 wheels. What is really dis-heartening is, the more I study the FSM, the more it looks like, to me, MR. T designed the ABS to work like this: If any wheel sensor detects lockup, the ABS will pulse braking power to ALL 4 wheels! If that's the case, that sucks! A well designed and most efficient ABS would only pulse braking power to the wheel(s) that are locking up. The other wheels would still receive full braking power. Real life scenerio: PS on ice, DS on bare pavement. The way this is set up, the ABS will bring the vehicle to a stop like all 4 wheels were on ice and it will take much longer to stop than if the ABS was deactivated. The only benefit I can see to the way this is set up, is if all wheels are on ice/slippery surface and during a panic stop, you need to steer to safety while your foot is jamming the brake pedal through the firewall. You can not steer if front wheels are locked up.
Front brakes always wear faster. But is it even possible to adjust the LSPV enough so the back brakes get used enough to wear them out quickly?
What I'm saying is, if you lower the LSPV all the way, as far as possible, would that even be enough to cause rear brake wear.
"i'm not an expert at this", but i think you may have a different problem, bad cylanders.... old rotors with 150 k on them. When was the last time you changed them.
It appears after some study of the ABS section in the FSM that the ABS, if it is working correctly, has 3 "channels" that are controlled independently. 1. Left front, 2. right front and 3. rear. My apologies to those of you who know that already, because I found it already discussed in the previous thread retrofive mentioned, post #10, by EricG:
https://forum.ih8mud.com/80-series-...ver-neighbors-bushes-bad-abs.html#post3983768
So if all is functioning correctly, the LSPV working with the ABS, should keep the rear wheels from locking up, regardless of load being carried and surface driven on. So, it's possible that if the LSPV is out of adjustment with too much bias to the rear, that excessive lockup on the rear or ABS activating unnecessarily might be a symptom. As was mentioned before, not adjusting LSPV after a suspension lift would leave heavy bias on front brakes, so you prolly would not experience this symptom. But if you take it upon yourself to adjust the LSPV, and you get rear wheel lockup or ABS activating on good surface with light load, the LSPV adjustment might be biased too much to the rear. Also, if the ABS is malfunctioning to the point of hijacking the brakes, as has been experienced by some and also mentioned in above thread, LSPV adjustment doesn't even come into play. I think you must first fix ABS , then work on LSPV.
just swap my old LPV for a new one this weekend .. ( real PITA bleed the system ! )
The old one ..
main.php
the new one in position ..
main.php
here you can see the marks for the factory settings .. ( all way to top )
main.php
I still have air in the system ! :frown:
