A couple of years ago, I did the OME medium lift (ugh, can't remember if it was 1.5" or 2.5") on my 97 and soon there after rebuilt all the brake calipers, put on new rotors and new pads. The other day I heard a scraping sound from the rear and upon investigation, it was both rear pads down to metal and rotors trashed. Front pads and rotors are as they should be. I'm assuming the LSPV is the culprit.
When I did the lift, I adjusted the LSPV by loosening the bolt that comes through the LSPV and attaches it to the bracket and moved it down by some amount and tightened it back up. I can't remember how much I moved it and when I crawled up under there today I didn't see any marks.
After doing quite a bit of searching and reading, I understand the proper adjustment is .25" down. But since I don't have a factory mark that I can find, I'm not sure how to get this back in proper adjustment. How do I go about adjusting this to ensure I don't trash the new rotors and pads too?
I'm hoping to take care of all of this over the weekend, so any input would be greatly appreciated!
Scott
Scott
Maybe someone can clarify this.
