low oil PSI ? - please help
Warsaw, Poland
I own Lexus LX450, 97
My OEM oil gauge was showing very low measurments, so I have checked oil pressure mechanicly. Measurements are as follows:
at 700 rpm- 7 psi (cold engine), 4.5 psi (very hot engine)
at 1000 rpm - 10 psi
at 4000 rpm - 66 psi
Is it normal or too low oil pressure ??
Welcome!
Believe it or not, we actually have another member from Warsaw (username: MikePL).
Anyway,
You should really get the Factory Repair/Service Manual if that's possible over there. For reference, the manual for my '91 (different motor than yours) states that with the engine at operating temperature, pressure should be at least 4.3 psi at idle, and 36-71 psi at 3k rpm. Maybe someone else can post up the numbers for a 93-97.
Cheers,
Curtis
just some information that may apply, not sure what to engine oil specs are for a 97, but mine are 10w-30. I made a mistake (wasn't paying attention) and put in 5w-30 on a prior oil change. a couple days later i noticed my pressure dropped real low and thought i had an issue. checking around a toyota tech told me that 4.5psi is factory spec at idle on my 94. took me a couple weeks to look at the receipt and realize i bought and used 5w-30. I went ahead and changed it out to 10w-30 and my pressures went back to normal.
I will feel little scary about that low pressure .. ( but as been posted not far out of the FSM specs ) .. I would feel comfy with more than 12 PSI at least @ idle ..
what are your outside temps and which kind of oil are you using .?
According to the 1994 FSM, oil pressure at idle when warm is 4.3psi or more
At 3000 RPM oil pressure should be 71 psi when warm.
Pete
Pete
Going from memory, I think the 3000 rpm spec is 38-71 psi. So the numbers listed here are normal.
I changed my oil from 5-40w semi synth cos my oild pressure dropped so much, now I use Mobil 15-40w ordinary oil, now my oil pressure is good, I do have posts on here with pics that show the difference in oil pressure gauge difference with the two oils.
Looks good. 71 is probably where the pressure relief is set, but I can't remember.
General rules of thumb. Cold engine, higher pressure..hot engine, lower pressure. Pressure should increase with engine speed, as the pump is engine driven.
So, at cold idle, the pressure should actually be a bit high. At warm idle it should be low. If the engine is extremely hot and the idle falls really low, you're going to see some extremely low pressures. All normal.
If it's a really, really hot day and you're running flat out on the freeway, oil pressure should actually be lower than if the temps were freezing out under the same conditions. As engine temp will determine pressure as well.
That's why there's such a wide range for the same rpm level.
At least Toyota was nice enough to give us a gauge that moved. Some other makes actually have resisters that keep the guage in one position no matter the actual oil pressure and then only drop to zero when the pressure drops to zero. Other rigs limit the range of the gauge. Because a real oil pressure guage will normally read near zero everytime you're stopped at the stop light.
