low fuel light always on
While the pump bracket is out check for chafing of the green ground wire that crosses the bracket, it's been known (rarely) to chafe all the way through the insulation against the bracket.
This doesn't show the chafed wire insulation but if you look closely you can see where the wire had been rubbing against the bracket. Some people have either zipped tied the green wire to the bracket or put a small rubber hose around the wire at that location, or used a section of heat shrink tubing over the wire at that point:
I did the same thing change my cluster with LEDs and low fuel light is on. Anyone have a FIX?
I just put back the factory bulb no more issue.
Awesome. Will roll everything back. Dammit
yeah took me a while to figure it out but alot of 4runner guys have this issue after swapping to all LEDs... i asssume that theres always a little current flowing as the lower the fuel gets the brighter the light gets.
Hey folks, I am still stuck yet again with mine illuminated all the time. I have diagnosed to connector and when doing that, the light goes out. I just swapped out my sending unit with another one and the darn low fuel light is still on.
The fuel filler neck from where the pump goes in to the tank is brand new.
I also checked the green wire on both for chafing and it was in near perfect condition. @Tools R Us
Lastly, the fuel pump was tested with a meter and checks out as well as functioning. I am literally baffled……
@fjbj40
@fjbj40
If it helps...
Mine was perfect into I swapped out the dash lights. I'm skeptical about it being the sending unit, but there's no doubt it makes sense.
What bugging me is a few of the LEDs that I swapped in aren't working, and I assumed I didn't seat them correctly. But if that's not it, then the LEDs are screwing up the system somehow, and that bulb is getting too much juice because of it.
That light slowly lights up at the fuel goes down, so it's calibrated to some extent. It might not take much to screw it up, and we may be locked in to the incandescents. One I can't stand it any longer, I'll roll back to oem for every single bulb unless someone had a solution before then
With these old trucks the membrane is easy to tear.
With some leds not working could be a broken circuit or even a led in reverse check polarity.
Incandescent light only for the low fuel light. That’s what fixed it for me.
Check continuity on the membrane circuit.
Thanks. I don’t have LEDs in mine, all OEM. I plan to take the dash out to replace the driver light which is out so can check at that point.
the updated leds are probably in backwards. i just went through all this and as @veiloctane mentioned above, polarity matters.
some larger leds have a little + or - on them if you look closely at the top of the neck closer to the actual light. the smaller t3 ones might not, so i checked each one with a small wire and marked the positive. on the cluster membrane, you can sometimes see + marks and also common ground marks. I was able to test with a multimeter and figure out that many use + on all the time, and seems they ground to turn on the light, kinda like the brights work on the headlights. a few tries of putting them in and testing as much as possible worked for me to get all my lights working in the dash, finally. and that also include the PRNDL2 lights a well. has to figure that out also. took two tries as i guess on one or two of the light and got it wrong initially. i think i have photos for the 80 series if needed
Has anyone else had this issue? my low fuel light is always on. How does that circuit work. I assume it's a problem in the instrument cluster.
We had this issue after the truck sat for 3 years, during which time I had the cluster out for bulb replacement.
After a couple of tanks of fresh fuel and some fuel system cleaner, it has resolved itself.
