Low compression on my 1978
JDNs78FJ40
Draper Utah
Hey Mudders looking for some advice. Did a compression test on my 2f that we are planning on mounting back to the frame this weekend. It has either 107k miles or a whole lot more. 60, 118, 110, 110, 90, 90. Was pretty cold, 40 degrees or so, engine has been on a stand for the past 12 months. The oil pan was off as well as the side cover and everything else is stripped off. It seemed to run fine prior to pulling the engine. Are these low numbers something to be concerned with if I’m planning on doing a swap in the next 15k-25k miles?
Since it seemed to run fine prior to pulling, I like Dizzy’s advice. Before I’d pull the head, I’d do a leak down test which would help determine where the lost compression is going.
I’d do a valve adjustment, a compression test, then a wet test... in that order.
