Low on the priority "fix" list but is still a fun puzzle. When searching I didn't find anyone else with the same issue:
Vehicle: '94 80
More than half the time when I turn on the headlights (switch in the low beam position) the headlights come on but the driver side appears to be splitting the current between high and low beam bulbs. (i.e. BOTH low and high beam come on, but both are dim). Driver side only, passenger side is never affected.
Flipping the high beams on and then off usually returns low beams to normal most of the time.
Is it possible for the switch to be failing in such a way that only the driver side is affected? If not the switch where else can low and high beam circuits mingle in such a way only the driver side is affected?
Vehicle: '94 80
