Louisiana/Area For Sale/Wanted:
yeas they come with a verry nice wireing harnesss and switch all heat shurnk and loomed
Micro switch and a relay, top notch set up. Welcome to the forum Rigid salesman.:p
If you ever need a replacement wire harness for those or anything else, give me the specs and I can put one together. We have tons of boxes with all kinds of components in them. Probably end up scrapping a lot of it this spring.
:) working on my commision with my buddy lol , no but i like seeing nice stuff that made in the usa,
What about the single dually? Does it come with a wiring harness as well? I wanna make it to where the single rear comes on with the back up lights, and can be turned on by itself.
If you ever need a replacement wire harness for those or anything else, give me the specs and I can put one together. We have tons of boxes with all kinds of components in them. Probably end up s****ping a lot of it this spring.
What you got?
I could use some micro switches and a couple of 4 prong relays for rock light set up.
Let me check...I'll get some pictures tonight also.
Actually, all of the switches are sold and the relays are a little high. Come with connectors and run a little more than $16.
He also has programmable controllers and temp sensors that he is interested in selling as well. Would work good as fan controllers or something like that.
Kind of high for some scrap, thanks for the offer but I can pick some up locally.
Yeah, it's all high-dollar stuff that he purchased in bulk while I was producing a controller system for battery protection and climate control. He sold a lot on ebay and is trying to get rid of the rest. We've tossed around the idea of making some specialty harnesses to get rid of the remainder and scrapping left over frames for other stuff. He also has 200 amp mechanically latching relays.
Anyway, this stuff is probably too industrial grade for most of the stuff we would use it for (lights, fans, etc). Although, I did use one of the smaller relays for my electric fan. The controllers are pretty nice though. You can program them with a serial port. I believe they have 32 inputs and 48 outputs??? You can set it so that when an input is achieved, you can get x for output. For example, you could have a temp probe on an input and while the temp is low, a cold start injector can run. Once xtemp is acheived, you can program it to cut off the injector and turn on a fan. It's pretty neat.
Again, more than most of us need.
What? Did you put a sticky note on the steering wheel?
...or write it backwards on your forehead and aim the rearview mirror up.
Mike I can't believe they are picking on you. Don't worry, I will remind you to turn it on before the ride starts...
:idea: :doh: I guess if I'm not there you are :censor: :whoops:.
