Loud 'knock/bang' Backfire?
Northern Territory Outback Australia
Hi all!
I'm not sure this has to do with the LPG system but am guessing it does.
I recently had to take the 80 over the pits where they stung me for a new LPG converter.. (the bit that converts the LPG to a vapour, has the coolant line running through it aswell.
I notice the LPG has been running a little low at idle, it ran at about 6000 on the dash instead of petrol 9000 or so so I just adjusted it to run at the same, but back to the story: Last weekend I took a left hand turn up a slight incline and BANG, I thought I'd hit a dog! So I turned around and nothing.. I was coming home that same trip and turned a different left, no real incline and BANG. I was sure one of my wheel was loose and about to fall off so took it real easy on the way home. I checked the wheels, nothing.. I looked under the truck, nothing I can spot.
It feels like someone whacking a hammer in the middle of the engine bay and kinda in front of my feet from underneath and accelleration ceases for about half a second. It didn't happen until just now again which is 5 days on from the last 2 occurrances and the same story, turned a left and BANG, no accelleration for 1/2 a sec and then fine. I didn't think anything of the fuel line until now because it sounds like a physical knock underneath, but with the loss of accelleration I must be wrong, unless I'm missing something.. (which wouldn't suprise me)
What do you guys think?
front diff?....intermittent backfire?... motor mounts?...
Thanks man,
The mounts look very good, I believe the diff it fine, no metal shavings or anything in oil, no loud motion noises from it, I just don't actually know if a 'backfire' would sound like a knock on the bottom of the truck body, and why does the truck seem immobilised.. Either a moving part or something is actually physically wedging and stopping the truck from moving (these trucks are pretty damn powerfl.. so I doubt it) or I'm just bot getting enough juice at the time it happens. It's only ever occurred at about 20km per hour around 90 degree bends,
I hope it just pisses off and never comes back.
I did do my brake pads and one front rotor (replaced) about a month ago too, thats the only thing thats changed along with the new LPG converter. I took a look under the hood around the converter last night and the only kinda suss thing I could see is a 90 degree bend in the coolant hose that come from the heater tap at the firewall to the converter. I thought that maybe it couldn't pull enough coolant when this was occurring, but its a long shot.
Pull the front wheels and check your brake pad/rotor handiwork...
Check bolts holding caliper in place, pins holding pads in place, check drive plate, studs/cone washers, preload etc etc on side you replaced the rotor. Could be something unrelated, but given you remove/replaced pads etc AND one rotor., the odds are pretty good that the problem is in that general area...
cheers,
george.
Thanks mate, I'm hoping not but you could be right. I jacked the truck up over the weekend and checked for wheel play, there was none whatsoever, I will take a further squizz though also.
Just spoke to the LPG guy whos also an associate and he says it could just be the fuel mix and it needs to be adjusted a few weeks after wearing in, which I already did yesterday so lets hope for the best. I really don't know what a backfire sounds like but this sounds and feels like a physical bang at around my feet, I originally thought the brake caliper had fallen off and swung hard to hit the bottom of the chassis, if you can imagine that sound. Or had hit a dog or had a large rock thrown up off the tyres
Can backfire sound like that?
Sounds like a backfire to me. Just went thru this on my wife's Heep Cherokee. It was throwing a code for TPS. replaced that but didn't fix it. It ended up being the fuel filter. Which suppose to be a non-PM part unless a specific code is thrown. It also plays a part in fuel regulation. The back fire was a loud thud. I thought the motor mounts were shot and the motor/tranny was hitting the fire wall/tunnel. So with you just having the fuel system worked on. I would guess you are getting a lean condition. Possible pressure related in a LPG system. Dont know much about LPG.:meh:
Thanks Swampie, very helpful. I haven't had an issue since adjusting the fuel mix, just goes to show, the best person to work on your 80 is you.. mechanics couldn't give a rats ass about what they might blow out. I could have blown holes in s***!! or, blkown seals out, who knows but it's not their money and they might even get more of it from you so they don't really care.
Cheers mate
Well, I took it back to the LPG guy, he listened to it, didn't even touch it then said it's good. I pulled out onto the highway over the weekend and that familiar knock/thump like I'd just hit something happened. This time I was on the highway where we have loads of road trains so I'm thanking my lucky stars someone wasn't killed..
Took it back to him today and I don't think he adjusted anything cause I know where the reliefs were set ad they haven't moved plus the truck still runs really slow since I played with it over the weekend.
WTF? Petrol runs just great, I found this online and have just tuned up to it but don't want to worry about every corner I turn out of fear of death..
http://www.fordmods.com/post597545.html
I guess all I can do is hope for the best now. My old converter seemed just fine.. So this guy collected $600 and almost killed me, good times! I thought it was supposed to be the other way around, you pay someone to kill someone else
I will throw out an idea. Could it be a wire in the wiring harness which breaks contact when the car flexes during a turn. Fuel keeps flowing but a spark doesn't fire. Then when the turn is made, and the body stops flexing, the spark comes back and you get the backfire from the unburnt fuel. It hasn't happened to me, but I remember reading about other people having problems with their wiring harness when the engine would flex under load. It was the usual place where the wires come down off the fire wall down past the EGR. Because your problem is with the LPG only, the problem should be with it's specific wires. :meh:
Well thats a very good thought because it's only ever happened around corners and to narrow it down even further, left hands turns only. I will take a look at that, thanks!
UPDATE** After setting the LPG to the link supplied earlier it's seemed to solve TWO problems (hopefully.. One for sure, slipping on take-off but time will tell with backfire) Please see here for the slipping thread https://forum.ih8mud.com/80-series-tech/593882-slipping-upon-takeoff.html and the all round smoothness and feel of the vehicle is much better. I don't know what the LPG guy does but it sure isn't any good. What a douschebag! Took me about 1 minute from start to finish
Real happy with the truck so far.
To anyone who may be interested, a little I found online about the problems of LPG that will not be attributed to A PETROL ENGINE AND WHY
13. Adequate Maintenance is Crucial....
It isn't only your ignition components that must be kept up to scratch....
A recent occurrence ( 5 / 10 / 02 ) gave us and one of our customers a unique but clear reminder of how important it is to keep on top of routine maintenance, especially on an vehicle that is converted to run on LPG.
Here's what happened -
The customer had asked for a re-tune of his LPG system, as the engine had all but lost its ability to idle on LPG under any conditions. Naturally we were interested as to why this should happen, the conversion was a long established and proven one, the car having covered several thousands of miles without a hitch.
The engine was run on LPG as slowly a possible without stalling and the gas analyser connected. It told us that the idle mixture was very rich. After some considerable adjustment, an acceptable idle was established and the fine mixture adjustment done. We couldn't think of any reason why the idle mixture should be so far out of adjustment - The vaporiser had undergone its initial 'bedding in' a long time ago and should not vary, especially to such a degree (two and a half turns of the mixture screw were required to get satisfactory readings on the gas analyser). We soon found out......
The engine was 'revved' a couple of times to make sure it performed OK before a test drive, but the second time the accelerator was pressed the engine backfired, blowing a large hole in the side of the airbox. Strange.....This car had not one single backfire since conversion.
We restarted the engine to find that again it refused to idle. Reference to the gas analyser showed clearly that the idle mixture was again well out, but this time it was too weak. Two and a half turns (back to the original idle mixture adjustment) brought the right figures back onto the face of the gas analyser.
So, what explains all of the events above?
It's pretty simple when all of the facts are considered....
The owner had earlier completed a 2000 mile summer trip to the South of France and back, in nice hot weather and dusty conditions...The air filter was so badly blocked by dust that it had severely restricted the air intake. This made the LPG idle mixture artificially rich as the air supply was reduced. When the idle mixture was leaned off because it had appeared too rich, it was actually ridiculously weak, to the point that it caused the backfire on revving the engine. When the hole was blown in the airbox the original (correct) air supply was restored, making the readjusted idle mixture show up for what it really was, very weak. When the idle adjustment was returned to its original (pre adjustment) value, all was well again.
This little account of events serves to prove how important it is to make sure that your air filter is checked regularly, and to show us that large changes in LPG performance often have a cause outside of the system itself.
Finally, note that the engine performed acceptably on petrol, which appeared to suggest that the LPG system was at fault - Nothing could have been further from the truth.
In a petrol injection system, the airmass (often called 'airflow') meter would detect that the air inducted was reduced by the blocked air filter, sending an appropriate signal to the engine mangement system (ECU). The petrol injected would have been reduced as a result, and the engine may have appeared to run as normal, especially as it is a 4 litre unit and has a lot of excess power. The LPG system on this car was not of a kind that gets airmass information from the airmass meter and thus it could not have done anything to reduce the amount of fuel it was delivering. This made the overall mixture apparentley too rich, most noticeably manifested in poor idle performance.
Whilst petrol injection is not directly dependant on the amount of air inducted, any inductive gas mixer system (closed or open loop) is, and if that airflow is reduced, the LPG mixture will appear to be too rich.
If there is a moral to this story, it is that whilst the LPG system may appear to be at fault at first glance, it may well be a problem caused by something else entirely.
It is not always the gas system that is at fault!
Another common misconception arises almost daily when we hear folk speak of their apparent problems with LPG operation - "It doesn't backfire on petrol but it does on LPG". The conclusion that the LPG system is at fault is then drawn, apparently a reasonable assumption to make.
However, this must be Red Herring No 1 when considering backfiring.
Recently we saw a car that later proved to be misfiring due to a faulty flywheel sensor. The fault went completely undetected on petrol because it cannot result in backfiring. There is nothing to ignite and explode in the manifold and plenum when running on petrol, only air. A stray spark will do nothing there.
BUT! If the manifold is full of gas/air mix (as it is when the conversion is one that uses a single inductive mixer) ......Well, we all know how that ends!
There simply is no point in thinking that if backfiring does not happen on petrol, the fault must lie with LPG. Yes, LPG is present, but something has to ignite it.
In cases like this, LPG is the victim. Sadly, it draws our attention to hidden faults by making a loud noise, showering us with bits and looking guilty!
An interesting footnote for those considering a multi-point sequential gas injection conversion (SGi) is that neither of the above problems can result in backfiring when using this system - The potential for large scale backfiring is practically eradicated by true SGi.
I'm just done replacing the air filter, here a comparison pic, does this one look particularly bad to you?
Also, after looking closer at the converter, I can't help but notice that the boys have stuck it right smack bang on top of this Toyota part (what is this?) and could the pressure of the converter pressing against it around left hand turns with flex cause the backfire/stall fault I describe? The converter is actually pressing against it (against metal part with the blue print)
Also, in the third pic you can see the wires that are attached to this part, a little crushed from (I suppose) installing the new converter.
I haven't yet driven the truck adequately but will be back as soon as I do, the filter is at least 50,000km old, probably more cause I've had it for that long and never changed it, who knows when it was last done prior to that
Ok I've found out that this part is the 'coil igniter'
Whaddya reckon, could play a role in my left hand turn backfiring..?
New air filter doesn't make a diff
Hi Croozer.
After 6 years is obvious that you solved the isse rugth? Im fac8ng the same stuff with the lpg.
The first hose from de air flow meter was cracked and i just take it off to "fix" and when i put it again in its place i started the truck, put it on lpg and BAAAANG it exploded and i dont know what the **** is... can you help me?
1991 fj80
