the tanks are non-leakers but the overflow is a washer bottle from some other rig. not sure what the application was, but it's "made in japan" and has a home-made mounting bracket on it. the washer motor does'nt seem to work. the bottles held water all day without leaking a drop. $20 for the pair.
$30 for the cluster; here are some pics:
Hmm, the washer tank looks diff from the one on my '74. I don't think my motor will mount up.
RE the cluster - does the speedo work? Odo?
i could'nt drive the rig with the blown engine, but if i turn the speedo cable input, then the needle on the speedo moves. so the speedo works for sure. not sure about the odometer, but i would assume it works as well.
$30 for the cluster plus shipping. it'll have to go ups because it's a little too big for the priority mail flat rate boxes.......
pretty sure it does. there's a red lense below and between the two green turn signal indicator lenses.
Is that for the high beams?
Sorry, I am not trying to belabor this, just want to make sure I can drop this in and have a working odo vs. adding another piece to my Cruiser stash pile in the back of the garage. Every 6 months or so my wife looks at the pile and says, "What is all that stuff?"
Looking for 6 prong voltage regulator? To 97701?
If pablo doesn't take the gauge cluster...I will. It beats staring at a rectangular hole in the dash, which is what I have going on now. Also, could you post up a pic of the steering column assembly, I need it for a 76 and I am thinking a 70 is different...so a pic would be helpful.
Thanks
Thanks
I'm thinking a three on the tree column may not be compatable with my 76 project. Anyone confirm this ? Orange..once we figure the column issue out...how do you want the $ sent ? PPAL ?
