If you have a non-Nav truck, I might be able to help.
I'm sure it'd be similar if you do have nav.
1. Pull out the center dash (see attachment). I find that massaging it out little by little, one corner at a time, works best and reduces the risk of breaking the wood.
2. Locate the harness that leads to the back cover plate of the A/C control panel (sorry no picture). This basically tethers the center dash, which you just pulled out, to the rest of the vehicle's harness.
3. You may unplug the harness from the panel so you can continue on the kitchen table or something, BUT remember which receptacle it is plugged into, so that you can reassemble later on.
3. With a small phillips screwdriver, remove the 5 or 6 small screws that hold the back cover plate in place. Once opened,
BE CAUTIOUS because you'll see a whole mess of circuit boards and wires. The back cover plate acts as a base for one of the two major circuit boards of the A/C controls. It's connected to the other circuit board with a tangle of wires.
4. Locate the temperature knob and do what you need to tighten it again.
5. Put everything back together and test your A/C to ensure everything's back to normal.
6. (optional) Don't do this today. It's Friday the 13th. Wait till tomorrow.
Hope this helps! Good luck.
- Cal
