Looking for Bushings
Would love to hear from guys that have replaced all of the bushings on improvements to ride quality, NVH, handling, etc. thanks
I believe my wagon tracks a bit more straightly after all bushings were replaced.
Didn't have any missing rubber or missing chunks. The rear control arms seemed to be in the worst shape. I forget if it was upper or lower, but they were cracking.
It tracks better on the highway now.
We (Dobinsons) have OE replacement rubber bushings for all 6 positions on the front radius arms. Made from natural rubber, and not as expensive as OE. Also have rubber 2.5 degree caster bushings as an option.
Dobinsons suspension components breakdown for 80 series
In my old LX450 with 160k miles, I pulled them out to put in new OME's with caster correction, and the bushings were fine.
Hi Crikeymike, I have a 97 LC with 2.5" OME installed by PO. PO says 850 springs in front and 860 springs in rear, but does not appear to have installed caster bushings. Will your 2.5 degree rubber caster bushings work with this OME lift? A friend recommended your products, but just want to make this would be a good match. Thank you!!
Yes they will, doesn't matter the brand of lift, these work for the lift height you have
