Longest 3" drop Pitman Arm?
Emigrant, Montana
Website
www.hubya.com
I have a 4.x turn 3 bolt saginaw box that i just put a 3" drop pitman arm on. About 5.5" center to center. I cant get close to my steering stops. I have looked all over and can't find a longer arm with a 3" (or even close) drop.
Any help at all is appreciated.
Running a shackle reversal, spring under, 4' lift maybe. 35s clear pretty well. Had a straight arm on it when i got it. 6.5" eye to eye. better turning radius, lots of bump steer.
Hmm, i understand the longer pitman arm. just can't find one! But where could the box go to get more steering? Centering it is a matter of adjusting the drag link arm, but i can't figure out how to get more steering out of it without a longer pitman arm. Now i understand why i have seen some ghetto fab pitmans. Chunks of steel welded onto a cut arm
the tie rod and drag link need to be paralel , if you look at it now it is probably paralel view from the face but if you look at it from over the space between bumper and rad it is angle like in that pic
I gotcha. So making the angle closer to ninety makes the pitman arm more "efficient". Moving the box for a little angle change seems like a lot of work for a little more travel. A pitman just an inch longer would be so much easier...
My angle from above is not great. But I know my box is in a similar position as others. seems there must be a better option for a drop pitman arm.
Maybe i will shorten my arms off the knuckle...
Hey guys,
I have a P/S kit from Advanced Adapters, but now I need a 3" drop pitman arm for my lift. Does anyone know of any CJ arms that have 6.75" inches from hole center to hole center? Rough Country had one that was 6.25", but it was for a Jeep Gran Cherokee, and I haven't heard of anyone making one of those fit.
I've been working on a solution to this and think I'm close. I also have a 4" SUA w/4x4 Labs box mount. As noted, the common 4" drop CJ5/7 pitman only has a 5.5" throw (and off-center spline clocking) . A 7" flat from AA is much better throw but bump steer is unacceptable.
Thanks to Mudrak, a suggested Superlift 1104 (used on Bronco) has 3.25 drop and 6.37 c to c reach (I got the tech diagram from Superlift to confirm). It will require a larger Chevy TRE at pitman, larger bore drag link w/tube insert for an FJ80 TRE at tie rod (plus need to ream TR for larger 80 TRE). All of this seems worth it for a stronger/better result.
Parts Mike has been super helpful running all of this down for me and I'll be ordering all of the above from them tomorrow.
Stay tuned for result by week's end.
The problem with switching from 5.5" long Pitman to 6.37" pitman is it only gives about 3/8" additional travel, but makes the steering react more quickly (much more touchy steering, not as gradual). This may not be significant, probably only noticeable when towing a trailer with your short wheel base.
Yes, I should have pointed out I have a 4.25 turn box, which is relatively slow. And I would never dream of towing with it. On my 40, the additional 3/8 will make a lot of difference in tight quarters.
BTW, if a little advertising won't hurt, I picked up a "chrome plated" pitman arm at the Pomona swap meet yesterday (Worlds largest hot rod/automotive meet), it's 6" centers, and drops 2" for mildly lifted rigs, but Mud guys don't have to buy it from my ebay store.
To close the loop on this search ... Parts Mike worked really hard on this quest and came up with what I think is an outstanding solution. Installed last night and everything works perfectly. Good turning radius, no bump steer at all, heavy duty parts, easy install.
Their (PM1104) pitman, modified off a Superlift 1104 (excellent suggestion off the top of Mudrak's head!), is 3.5" drop, 6.5" center to center. It takes GM 1 ton TRE (EX2234LHD). That couples to a DOM 1.25" - .25" wall threaded tube with 7/8" - 18 threads (TT30H). Cut the RH end off to your length and weld on a FJ80 bung insert (TG130319-KIT). Ream (Reamer is TG130319-KIT) your stock 40 Tie Rod to accept an FJ80 RH TRE (FJ80R).
Don't let all this scare you away. It literally took me 5 minutes to ream the TR with a 1/2 drill and, because of waiting to cool between welds, 1 hour to weld, 15 min to paint, 15 min to put it all together. The end result is as near perfect as I could hope for and way heavier duty than AA or CJ5/7 conversion parts.
