Longer Wheel Studs?
ET lugs can offer some extra length if you are using a tapered seat wheel. Not sure if they will be enough for wheel spacers though.
The front studs seem to be longer than the rears but is length the only difference? Meaning, could you install the longer front studs in the rear drive flanges?
Smitty, Can you please provide a part number for the ET lugs that worked for your application. Also what wheels and spacer are you running? I am trying to determine if these lugs could allow Rock Warrior wheels to be used with a narrower spacer instead of a 1"+ thick adapter. I have some tire rub with my 1.25" adapter.
Thanks in advance.
