Longer Crank Times
SmokingRocks
hopelessly addicted to Cruisers
Colorado
Took my fuel pump out yesterday to see why the engine was stumbling intermittently.
Found this on the filter.
Put a new filter on and stuck it back in. Truck ran great, no more stumbling.
But now I am getting longer than normal start times. I am wondering if some debris was able to get into the pump and maybe affecting the ability for the check valve to hold pressure in the system. Thoughts? I am positive this is fuel related as it did not exhibit this behavior prior to fuel pump service.
If I put the key to the ON position for about 5 seconds before cranking, it will fire right up. Why couldn't Mr. T put a shrader valve on the fuel system?
I'm pretty sure the fuel pump will NOT run with the key in the ON position (if the engine is not running). i.e. from off to on and prior to cranking the fuel pump won't be running. It will pump during cranking and while engine is running.
Additionally... Their is a fuel sock (quite fine 'pore size') over the intake PRIOR to the pump, so either that has disintegrated or your fuel filter had a hairball episode. Time to look inside the tank...
cheers,
george.
Yea let me clarify.
This was found on the fuel sock. I guess there is a filter after the pump?
And yes many many cars will run the fuel pump when the key is turned to the 'ON' position in order to prime the fuel rail. They turn on until pressure is reached (usually 2-5 seconds) then they turn off. The 1Fz-Fe is no different.
There is 160k on this rig. The fibers look like the sound deadening material that is under the carpet.
The previous owner had hot stall out issues and I think they replaced the fuel pump. Based on how terribly they did everything I imagine they let some fibers fall into the tank. Didn't check the manufacturer on the pump but I do remember thinking it didn't look like an OEM pump. I have been pricing out a Denso replacement.
No - I'm pretty sure that the fuel pump does NOT run on the cruiser unless cranking or engine is running. I know the corolla I have DEFINITELY does NOT run the fuel pump unless cranking/running - on the corolla I am 100% sure of that!
Yes, of course there is an actual fuel filter - it lives under/just in front of the intake manifold.
If that was in your tank, make sure the rest of the tank is clean. Probably crap that was pumped in from a petrol station.
cheers,
george.
I know there has been a lot and I mean a lot of debate about when the fuel pump is on or not. Based on my 30 mins of searching (yep I did search :p) I believe that the following is true.
The pump is on during the following situations:
  1. In the ON position for 2-5 seconds
  2. when cranking
  3. while running.
My hondas, audi's and saabs all exhibited the same behavior.
Sounds like replacing the fuel filter is a PITA, and knowing that its there leads me to believe that the pump was the issue. As stated above I think the PO replaced it with a cheapy one while trying to tackle a different issue, probably introduced the fibers to the tank at this time (same fibers that the pad under the carpet is made out of). Probably best just to get a Denso or AISAN unit in there with a new sock.
I choose to differ on your belief the pump runs for a few seconds :)
The simple test would be to put a meter on the +/- feed right at the pump connector and see if you get +12V for those few seconds...
Yeah, OEM pump is probably a good idea for long term. I presume you looked in the tank to make sure there's no other carpet/hairballs waiting to clog up the sock.
cheers,
george.
I did look in the tank there was some fines that had settled out right below the sock location, I've seen much worse in other tanks before. Other than that and the fur balls the tank was squeaky clean.
I'll test it next time I'm down there and let you know :)
I am actually thinking of soldering in some wires to an LED so that I can have a visual notification that the pump is receiving power. That could help expedite troubleshooting breakdowns in the future.
Confirmed that the PO changed the fuel pump. Freakin moron, should not be allowed to have tools based on all the s*** he screwed up on this rig.
I'd personally replace the fuel filter given the history of crap in the tank. Slot the filter mounting 'tabs/ears' (it'll be obvious when you are in there trying to replace it) - makes it easier to install and to also remove/replace next time. Filter has crush washers on each end where the banjo bolts go in. Pretty sure the OEM comes with those washers. Not a place you want any leaks given it's nominally a high pressure fuel rail...
cheers,
george.
