- Joined
- Jun 28, 2019
- Threads
- 36
- Messages
- 452
- Location
- Highlands Ranch, CO
- Website
- coachglenndavis.com
I've been doing a lot of maintenance the past two weeks (spark plugs, front/rear diff oil, xfer case oil, engine oil, power steering fluid, brake fluid flush/rotors/pads, coolant flush/thermostat/hoses, serpentine belt, etc.). This is in preparation for a trip from CO to MO in a week. We've only had the cruiser since late June and I want to make sure she's as fit as possible based on my availability.
Would it be wise to replace the high and low beam bulbs? If I should replace them, for now I'm going to do the standard oem-equivalent halogen bulbs. I don't want to pay more for an increase in brightness but a shorter bulb life. With my prior Subaru Outback, I never knew when a bulb was going to fail.
Also, after looking at my owner's manual and what some manufacturers recommend, I'm confused. For example, the low beam is a 9006 H11 and the high is a 9005 HB3. Should the replacement have these exact numbers? I've seen 9006s and 9005s with different letters and numbers following.
. It'll be a quick death for those spares!
