What is the best configuration for towing with a FZJ80? Pwer button, overdrive? Does tire size really make a huge difference with stock gearing? Ideas? I am moving from Ft Worth, TX to Everett, WA in a month or so and need to know. Or should I sell my cruiser and get a diesel?
I only tow a utility trailer around town, but I using the power button is the way to go, in fact I leave it on most of the time anyway. I would only lock out OD if/when you have frequent gear "hunting" from OD to 3rd, like going up a long grade.
First, welcome to North Texas. I was raised in Ft Worth, and now live in Weatherford (25 miles west).
For towing, first make sure your weight is within guidelines of what the Cruiser will handle. There are specs, but my rule of thumb is 5000 pounds, MAX. I also make sure whatever I tow is not bigger than my rig. I am more concerned about stopping than I am pulling.
You can probably pull down a house with one of these if you have good traction, but stopping under load is another kettle of fish. I pulled a cargo trailer that was 7X10, fully loaded, several times from Houston a few years back. Stopping was thrilling, and terrifying, all at the same time. Doing 85 - 90 was no problem.
both trailers I tow have electric brakes that will stop my truck as well. You leave your O/D on when towing on flat ground. I thought that would wreck my tranny?
Ben's got it. Straight from a Toyota powertrain engineer - "Leave it in D and let the tranny choose gears unless it's constantly in/out of O/D - then lock out O/D for that hill.". Be sure the tranny fluid's been recently serviced, and all other drivetrain and engine fluids, the cooling system's up to snuff, the brakes are checked, and you have a quality frame hitch, and the tires are up to the task and properly inflated, recent engine tune and filters. Personally, I'd have the truck in the kind of shape you'd want for an extended expedition in terms of maintenance.
I also installed Airlift airbags in the rear coils to tow nice and level. Lots of discussion on those here.
