For Sale Long Beach, CA
Long Beach, CA
Year
1996
  1. 80 Series
  2. LX450
Mileage
270000
Color
Black
Outside Link
https://www.facebook.com/marketplace/item/1125083342422168/?mibextid=wwXIfr
Finally listed for sale, 1996 Lexus LX450.
4” Slee lift with OME springs & shocks.
Triple locked with Toyota OEM e-lockers.
Wits End Turbocharger kit, adds 100hp at 6lbs of boost.
Preventative maintenance in 2019 with turbo install. HG replaced with Cometic HG, cleaned/blue printed injectors, upgraded all cooling components with Ron Davis radiator, blue fan clutch, OEM auxiliary fan.
ARB front bumper with three Black Oak LED light bars, 12k Smittybuilt winch.
Custom side rails rocker panel protection with catalytic converter cage.
Custom rear dual swing out rear bumper. Has full size spare, hi-lift jack mount, & DeltaVS fuel carrier.
Converted brakes over the GM-style hydro boost brakes system by VanCo. Replaced all calipers with OEM originals just recently as well as all new suspension bushings.
Running Nitto 35x11.5r17 tires with factory 17” Sequoia wheels.
Comes with factory service manual, spare parts (factory & aftermarket).
Numerous sensors, spare parts, additional ECU, filters, tire chains, ect.
JRP 14-in-1 gauge that monitors booster, AFR, oil temp, water temp, oil pressure, EGT, with programmable warning indicators for each sensor.
Whelan electronic air horn siren module wired to wheel horn assembly with additional PA speaker system installed for fun.
Asking $25,500.
It is a CA rig.
I’ve owned it since 2008, it was a CA rig prior to me.
It does have a salvage title. There was something broken in the front axel, from a collision, prior to me purchasing, so I had it AAA towed home from the yard.
I ended up swapping both front & rear axels with the Toyota e-locker axels shortly after I purchased the vehicle.
Vehicle has been great the entirety of my ownership with numerous upgrades over the years.
I do currently have a valid smog certificate from within 90 days, so purchase will be hassle-free.
The turbo will fail the visual inspection in CA unfortunately. Luckly it won’t need smog til November of 2026, so well over a year.
It’s a day job to swap an intake hose & factory down pipe for a quick weekend smog check every couple years.
Nice looking truck..GLWS. Would you possibly be willing to sell the Witts End fire extinguisher mount separately?
