Locking Differential Question
Weiser, Idaho
Hi all...this is my first post to the forum, and I hope ya'll can help me with a question. I've owned a couple of fj60's - but just recently purchased my first fj80...and I'm a bit unfamiliar with the diff. lock system.
It's a 1992 with the center diff. lock. The guy I bought it from told me that "something" was just replaced in the system and it's suppose to be 100% working. (he said it cost $850 for a rebuilt part, but didn't know the exact name of the part)
The mechanic told him, and he told us, that it has to be run with the diff. lock on...if fact if you take it off, it makes a terrible grinding noise, and it doesn't move at all.
My question is...is this normal? Is the diff. lock suppose to be on all the time in order for the vehicle to even move at all?
Thanks any and all for your help.
Jon
You should run it on the street unlocked. It sounds like something is broken, on the early trucks the front drive plates have shorter splines, are weaker and prone to striping.
that sounds like what happens when you dont have the front or rear driveshaft in. Have you check to see if both shafts are ok?...In?
Possibly something going on with your transfer case.
That's kinda what I was afraid of.
Three questions:
1) Let's say it is the splines striping, how would I check if it's that....and any idea what the cost is going to be to fix them? What does it entail?
2) If it's not the splines...any other options it could be?
3) Apparently the guy I bought it from has been driving it for at least a year with the diff. lock on all the time...what affect would this have? Would it be damaging?
Thanks,
Jon
That does not sound good. If you can't find someone local who really knows cruisers to help you assess it, I'd find a well known local shop specializing in cruisers and take it there. It might not be as bad as it sound$, and the professional assessment might help you take some money off the asking price. The low buck way to do it would be to get some help from someone on a local club. There are almost always cruiser enthusiasts who will take the excuse to look at any truck and will help you out for next to nothing!
It could be the splines on either or both the drive flanges and birfields, the ends of which go into the drive flanges.. More likely both, unfortunately. It could also be any component of either axle, but the drive flanges/birfields are the most likely culprit. They are the most common problem that causes those symptoms, and the most likely to be quiet with the CDL engaged.
A friend of mine just replaced both his birfields and drive flanges with the newer, longer splined style. Aftermarket birfields ~$400/pair from Man-a-Fre, drive flanges ~$220/pair from the local Toyota dealer. A front axle service is recommended at the same time as you will be 80% there with the removal of the birfields. The seal kit with trunnion bearings is ~$130 from Man-a-Fre. I use Man-a-Fre/dealer pricing only because that's who we used, there are other vendors.
You might want to throw a location in your user profile, someone local to you might offer to help. You could also toss your year and major modifications in your signature if you don't want to repeat yourself every time you ask a question.
-Spike
Three questions:
Remove the center caps on the front wheels and the small metal caps under them, unlock the CDL, have a helper start the motor, put the trans in gear and look at the shaft end that's under the cap, if one is turning, the splines are striped. The drive plates are relatively cheap, but most of the time the birf splines are also damaged, they aren't so cheap! The good news is that you can upgrade to the later, stronger ones and never have that issue again.
Thanks,
Jon
There could be other issues, but the splines are the most common. Probably wont cause damage to anything else to drive it, but it's only rear wheel drive. Do some searching, there are some good threads and pix posted on this.
Thanks ALL for your help. Looks like I've got some research to do. If I run into questions...I'll let ya'll know.
I've also updated my profile...I'm located in Weiser, Idaho (about an hour north of Boise)...so if there's anyone in my area that could help a newbie figure this out, I'd sure appreciate it. Hell, I'll even give myself the newbie salute! :flipoff2:
Jon
with the CDL unlocked it would transfer power to the slipping component, so the inspection other have spelled out is the ideal. If the CDL locked means forward motion it simply means that the rear is driving and the front is not. Sounds like front axle since the t-case eating itself would not bypass simply by engaging the CDL.
