Lockers ???
Power steering?
yeah, sack up will ya! don't knock strong-arm steering, give it a couple of months and either you won't complain or you will get it done. A lot of threads and users of this site say its the best mod they have done, I disagree. I like the feel of no power steering. It may be a lot more work but if your rig is mostly going to be used for on road, it may not be economical for you to change over. IMO.
FJ40 MNTCRZR said:
POWER STEERING PLEASE ... a guy over at marlin crawler sd i can get a chevy power steering unit it needs a number stamped on ? 79 rings a bell ..? is this true and how hard is the power steering conversion ?
" 76 ".....under the area where the input shaft is located.
Hit the F A Q and read away on this, and many other topics!
A stock or slightly modified truck on the road or on the trail without power steering is fine. Run larger tires and a locker in the front, and you are going to want some help getting them to turn.
Good luck!
-Steve
good luck on what you decide to do i did about a year of research before i started building my rig also wheeled my daily driver a 78 fj40. then bought a 77 fj40 and went to town. here is what i went with but am currently 4 linking front and rear with coilovers and going full hydro steering. keep in mind this truck is a trailer queen but the selectable locker is nice for a dd.
strected wheelbase to 110"
arb's front and rear
dui elect ing
motocraft 2150 carb
header
marlin 4 70 1 toybox
saginaw power steering 4 bolt
some of these options may not be nessecary for you. i would wheel your stocker for a bit and see what you need and how far you want to go. i think you will be very impressed with how well a stock 40 will do i know i was.:cheers:
You've got some work ahead of you, but it's very do-able. I wheeled my rig for a couple of years w/ manual steering. However, when I put 35's on PS was a must.
1st, you need to decide what steering column you're gonna use. Stock, Ford/Chevy/?, or aftermarket. Get a new steering wheel:cool:
2nd, get whatever PS box. Make sure it's a 4 botl style. I currently have a 3-1/2, but have 4-1/4 in the shop w/ my name on it. Biggest difference I know between the 2 is control of the turn. (Give Orangefj45 a jingle, he and many other on here sell the PS plate set up.)
3rd, I called Advance Adapters and ordered in the plates, stub adapter, and shaft.
4th, get to work on the fab abilities. Somewhere I have the ps pressure hose # I used. You'll need to get a hold of man-a-fre for the 2F p/s pump bracket. It does not come w/ a pulley. Somewhere I have the double groove pulley number too.
5th, new pitman arm.
Hopefully I haven't missed anything.
Good luck, and a worth while mofd if it's how you want to go,
Campy:cool:
