I went with ARB. From all my reading, it seems the biggest issues are with the air lines breaking. I thought the plastic air lines going to the diff were cheesy. So I had a shop make me custom length hydraulic hoses with the BSPP thread the ARB fitting uses.
The flexible and very strong hoses go to the axle and a union fitting mounted to the frame that I got from McMaster-Carr. The plastic air line then goes to the fitting. That way the plastic line doesn't have to move or get fatigued like it normally would.
An open differential sends the same amount of torque to both rear wheels. So if one wheel is in loose gravel and can only take 200 lb-ft of torque before it starts slipping, the other wheel on solid pavement with traction also only gets 200 lb-ft of torque. The high traction wheel torque is limited by what the low traction wheel can take.
Torsen differentials work in a similar manner, but have a "torque bias ratio" that multiplies the amount of torque the high traction wheel gets compared to the low traction wheel. The Nitro product seems to have a torque bias ratio of 3.5. So in the same scenario as above, if the wheel in gravel can take 200 lb-ft before it loses traction, the wheel on pavement will get 200x3.5, or 700 lb-ft, allowing you to put down much more power.
Sounds great! So what's the issue then? Well, what happens if you have one wheel in slick mud, ice, or you're flexed enough that a whole tire is off the ground? A tire with zero traction requires essentially 0 torque to start spinning. 0x3.5 = 0, so your high traction tire gets no torque, and the differential behaves as if it were an open differential.
Torsens are great, but just be aware they have some limitations in certain situations that will make them functionally equivalent to an open diff. There are some "tricks" you can do to work around the quirks. For example, applying your brakes to load up the differential can help bias more torque to the high traction side.
Torsen differentials are great on the street and mild off-road conditions, but have some "quirks" that can make them behave like an open differential.Since no one has mentioned it, anyone running a Torsen style LSD/Locker? Nitro makes one for the 60 series, and it sounds like a decent option for light wheelers that also want more on road traction in snow and ice with better predictability than a full locker.
