Lockers Question
Vidor, TX DIXIE
My tacoma I have now has loc rites front and rear with manual hubs.
Let me know if I understand this correctly since I may be getting an 92 fj80 soon, that the reason people recommend ARB or stock lockers over locrite/detroit is because with the awd system the truck will be pulling the whole time your driving? Like my truck if I left the hubs locked but took it out of 4wd?
the fj80 im lookin at is a decent deal, but unlocked, and i'm spoiled to lockers however i am not wheeling this fj like i did my taco.
An automatic-type locker like an Aussie or Detriot isn't recommended for the front diffs... Mainly because of the full-time 4WD. That's what I was always told.
If you left your hubs locked in 2WD, all that would do is cause unnecessary wear on your front end. The wheels would spin the axles, axles spin the d-shaft, then the d-shaft would free-spin inside the t-case. No idea what the consequences would be.
HTH
-Lane
I would only run an Aussie locker or similar in the rear. Then I would use a selectable locker for the front so you don't have as much binding during street use.
It'll get kinda scary on slippery roads with a an Aussier or similar in the front and rear.
Selectable in the front for sure.
Rear is more about your preference...an Aussie in a 92 is a great, low cost solution for the rear ( am running one in my 96 on 37s and it holds up fine).
The 92 will have a Center diff Lock which makes it just a capable as most rigs with a rear locker. With the exception of another 80 of course!:doh: It could keep up with your taco. Wheel it first and surprise yourself and anyone you wheel with that your 'open'
I understand what the CDL does. When rear slips both frt and rr engage at the same speed through the t-case(right?) then how is that anything like a comparing it to most rigs with a rr locker?
Im just trying to get my misconceptions straight. Deciding if I get an unlocked LC if it is worth it.
Maybe "just as capable" in your opinion, but the fact is that an open front/rear diff 80 (like all 91-92 models) with the center diff locked is exactly the same as a part time 4wd rig (such as a Tacoma without a rear locker) with the T-case in 4hi/lo.
Curtis
Curtis
Thanks for clearing that up. I can use the same locker that a 80s model Toy Truck/4runner uses correct? I thought I remembered the rear thirds being compatible with one another.
