Locker inquiry
I know I'll get blasted for asking, but in defense I have been reading forever, and the only threads I can find are on the lights for lockers blinking, but lockers not coming on.
Mine all of a sudden went dead. No lights come on at all, and I can not hear any click noise when I turn the switch. The center differential is locking up fine when I use it.
Whatever caused it happened suddenly, because it has only been a couple weeks since I last used them and they worked fine.
I recently installed a 2.5 inch lift and was wondering if I could have bumped something maybe.
Anyone encountered this same problem by chance?
Was your CDL engaged when you tried your lockers?
Unless you have the CDL switch you must be in low range.
You should put your rig in your sig line so when you post a question everyone knows what year your 80 is.
I been meanin to update that signature, should be working now. But yes, the cdl is engaged and it is in 4 low, but I get 0 response from the lockers all of a sudden, no flashing lights, nothin.
Check the plugs at the actuators to see if you are getting current...might have an issue with wiring getting buggered during the lift?
I don't suppose you had your dash apart recently? Might just be a loose plug? :)
