Locked 3rd member swap
Axles in rear and u have to grind case to clear actuator .
rear pass side inner axle is shorter, some grinding and welding, wiring is not there for running from rear 3rd up to harness in back corner, then you need 3 or 4 wires up to front driver footwell. you need lightbulbs in dash, the computer for locking axles unless you are just doing relays, the magic switch, and a lot of beer.
