Lock and Roll
Colorado Springs, CO
Greetings Mudders, new guy here. I'm currently a Jeep XJ guy, but looking to make the jump and become an FJ guy. They seem like such a great platform to start from when building an offroad rig, but judging by the prices, that secret is already out. :eek: I mean, how can you beat F/R lockers from the factory?! Speaking of lockers, check out this 80 on eBay - it has the locker dial, yet it has the K292 sticker code.
Toyota : Land Cruiser 40TH ANNIVERSARY
As I've already learned on your great forum, something ain't right there.
While we're on the topic of lockers, I haven't read yet about the durability of the factory lockers. How strong are they? How do they compare to an ARB? And how do the ARB's seem to hold up in the 80s? I'd like to find one with the factory lockers, but would also think about putting ARBs in if I found the right one that didn't already have them.
Welcome jeep guy. The factory lockers carry the same theme as everything else about toyota's flagship vehicle: Reliable and durable. I currently have ARB's and they work very well. They have no known durability issues. I had an 80 with factory lockers for a short time and I can tell you that the ARB's actuate quicker. Read up on the factory units before you go chasing after a locked 80. Not saying there is anything wrong with them, but having used both I much prefer ARB's.
If I were to get lockers I would want the ARB lockers. But I don't feel any need for lockers so I don't worry about it.
Buy an 80 and never look back. With or without lockers you will be impressed and wonder why you didn't do it sooner.
The factory lockers will actuate pretty quick if you use them regularly. I've had both factory and ARB, and both are good. I did have trouble with air lines a couple times, they seem to struggle a bit when it's really cold. Both are great and you will be happy either way.
I'm running an ARB locker coupled to the factory dial switch. Maybe the owner of that rig did the same.
Welcome. IMO, the only significant consideration between factory and ARB lockers is if you are running big tires and wheeling hard. The splined section of the shaft can twist in the factory locked versions and make it impossible to replace the axle shaft without a torch. See below for more info.
Twisted rear axle shaft
Thanks for the info guys. Yes, perhaps I shouldn't prioritize a lockers to high when looking for an 80. I do think a factory implementation would be cool, though. Everything is already there, no airlines to melt (which I have done), no noisy compressor.
I've run both and they seem to perform about the same. Never broken any parts with either, but I also practice a fair amount of mechanical empathy. I will agree with baldilocks, the ARBs do kick on a little quicker, they also disengage quicker. With the e-lockers, I find myself sawing at the wheel (or worst case, putting the truck in neutral and rolling back a foot) to get the locker to disengage. This is a rare occurrence.
The main reason I went for a factory locked truck this time around is for the convenience and cost. There are still a few soccer moms out there who don't know their trucks have lockers. Sometimes you'll find a good deal on a truck that already has them. Dual ARB install is not cheap, and generally that cost is going to be bigger than the difference between a locked vs. non-locked LC in the classifieds.
