Local For Sale/Wanted Section!
Doors
I've got a pair of pre 74 fj40 front doors for sale. Doors are red driver side door dented towards bottom. No rust. $150 obo. 75 and newer hard top with amby doors. Doors are black have rust on bottom, repairable. Top has no rust. $400. stock 4 speed bellhousing $25. Other parts laying around ask and I can take a look. Thanks, Dan. 610-360-9549 best to reach me by phone.
Need FJ62 catalytic converter
Hildy or whoever- a guy from Virginia asked me if anyone has a used catalytic converter for an FJ62. I thought maybe Hildy might have something or maybe someone else. Can anyone help? let me know. Thanks, Gary S
Dana 60s - $400 - Ephrata
All,
I am moving next week and have a set of D60s sitting in my garage that I would NOT like to take with me!
The front is a Chevy (Passenger side drop) dually axle converted to SRW with Dodge parts - and with 35 spine drive flanges. It is a 4.11 diff, has no brakes on it (I was planning to use 3/4 ton brakes), 35 spline inners, 30 spline outers.
The rear is a Ford 3/4 ton full floater. I don't recall the ratio on this one but I do know it is not the same as the front. It also has no brakes and would need bored out to have 30 spline shafts (there used to be a few boring tools floating around locally).
I don't have pictures, but they are as-pulled (not painted or cleaned) and have a light coat of smurf blue paint on them.
CAZ
It needs brakes, histeer arms, 35 spline outer shafts (similar to the birfield on a Toyota), u-joints, and some TLC.
You would likely want to get a conversion kit for smaller brakes on it. The 1 ton brakes are expensive - not to mention HUGE! You need smaller brakes to fit a 15" wheel.
OLD pictures - I had them mounted up and then bought my 40 and scrapped the project. They are FULL WIDTH axles. They would only be reasonable on a Toyota with something like the Hummer wheels I had (7" backset").
main.php
main.php
Let me get some things figured out, I would need to unload my Toyota front axle that I built for my 4 Runner to get this in its place. I would be looking at running either H1 or H2 rims with 42" Iroks or 40" LTBs on the 4 runner.
Did you clip the low steer mounts off the knuckles? That would be my biggest issue since I am planning on low steer with just crossover since I am only going to be running about 2" of lift.
When do you need these gone by?
22r for sale
22r, i think its from an 85, right now its a long block, but i have the intake/carb, exhaust manifold, flywheel/stock clutch, distributor, and i think the rest of the accessories for it(ps pump, alt, starter, etc...)
the oil that i drained out looked ok, not sure on how many miles, the valve cover is really clean , and i have some extra new gaskets and seals for it
located in northumberland, pa 17857, but i can get it to the first rcrocs for free, or to A-Z in schuylkill haven on any weekday
$100, i also have a 1000lb capacity engine stand that can got with it for an extra $50, it just needs a new caster
sold
FS my Green 94 cruiser brown cloth interior. 187K on the clock. Runs great , kyb shocks and 315 (33") BFG mt with less than 20K on them. Good brakes all around, Pa inspected. newer rotors up front.
Bads. It will need a birf job in the future, kinda gooey under there. I do have a set of low millage birf and axle to swap in and the rest of the parts to do a quick birfield job. It also has a leak at the O2 sensor. I had one fixed at a local shop but he did not do the other. I have a set of really nice down pipes included. Just swap them in. I do not know if the headgasket was ever done. I have not observed any of the signs that it needs it. It does leak a bit of oil around the front of the valve cover. It's not perfect there's a few little dings and some light scratches.
I also have a spare rear hatch and all the stuff in there, I have the original running boards. I did have to fix the one rocker corner but it came out good with nice clean metal. no other rot.
I'm in pa 18707
bob
Doors FJ60
I have a pair of front doors fro an FJ60. The doors are in great shape (silver). Both doors include weatherstripping, window mechanisms, and glass. Asking $475.00 for pair. Any questions just ask.
I am in Dillsburg, PA.
help me i swapped my rear aussie locked third to the front and welded the new rear. problem is i cant find my old, i believe pinion spacer, it keeps the c-clips from falling out anyone got one they will let go cheap I wanted the truck done for this weekend oh well.. Just did a so and itching to beat it by the way its a n 87 fj60 if it matters and im in shrewsbury pa. help a brother out thanks guys
Bryon
Peg Perego Gaucho
My son (3) and I were looking through old pictures and he saw A photo I took of my red 40 now sold and said Daddy's mud truck, it's gone now (ouch), now we both like the 80 but is is not a 40.Though he still likes mud trucking in it! I have a 40 frame/semirolling chasis, thanks to Gary. But, I need a Peg Perego Gaucho to get by with my son's cruiser addiction, if anyone sees or has one, my son and I will appreciate it.
Thanks, M. Reed 610 6036861
