lj78 transfer case seals
bc canada
checked around the forum, couldn't seem to find any part numbers for transfer case seals. lj78 with 4 spd auto. any help would be appreciated. Front transfer case seal is leaking, and while im at it , what tranny and transfer case do i have. i'm a little confused here. Also will a 5 spd manual and transfer case out of a older 4 runner fit, will i have to change drive shafts etc,etc.:cheers::cheers:
if the front seal is leaking then i would check the internals for damage as well ...
of course if the seal went because of swamp grass getting caught around the shaft then that is understandable.
John at Radd Cruisers will have what you need as well.
my computer (MAC) won't open the manual link above. the seal i need is the one on the front of the t case, right where the front drive shaft comes out. there is just one drip down the front of the case. no drips on the ground. i don't think it s to serious. is this the 90311-48009 SEAL, OIL (for output shaft bearing front retainer) thanks for your help
sheesh, no worries at this point. when it starts leaving toonie size drips everywhere then worry about it...
