Lj-78 2L-TE help need manual
Hey guys I need the injection pump timing settings for my 2L-TE engine ASAP please I will buy a manual if it covers the 2L- te engine
2LTE times it's self. All you need to do is match the marks on the outter ear of the pump to the part it bolts to. If your timing is out, it's because your timing belt is out a tooth, or the timing control valve in the injection pump has failed or has issues.
You can download it here.
L_2L_2L-T_ENGINE_FSM.pdf
That manual is for the earlier rocker cam version of the 2LT.
Lots of differences from the newer 90+ 2LTE and 2LT-II. The manuals are on the forums here. I can give the original poster the links to them when I have time to find the threads they are in. No time now, will post back in a bit, sorry. Search and you might find them.
Maybe this one?
From 1990 and has injection timing.
2LT ENGINE SUPPLEMENT_1990.pdf
Yup, thats the one. To the original poster: That manual applies to everything on your motor except for the injection system (because you have the electronic version, but the manual is for the mechanical version).
Here is a manual that explains how the 2LTE injection system works:
V 3 P5ZGR01.pdf
Here are a couple newer manuals than the one Beno posted. Basically the same thing, just a bit more of it:
RM520E (Main for 2L, 3L & 5L engines)
Dropbox - 2L 3L 5L ENGINE RM520E.pdf
RM582E (Supplement for 2L, 2L-T, 3L and 5L engines)
https://www.dropbox.com/s/1joci2o0xtg6ujv/2L%2C2L-T%2C3L%2C5L ENGINE SUP. RM582E.pdf?dl=0
Finally, if it's a Prado you are working on, here is the manual that covers the rest of the vehicle RM183E:
_KZJ70_HZJ_PZJ_chassis_body.pdf
Just remembered, but this video explains the 2LTE injection system very well. Don't mind the 80's graphics and sound effects, lol:
