Liquid gold.
Paso Robles, CA
So I just recently purchased my '91 FJ80 from a private seller. He was a nice older gentlemen who was quick to point out everything wrong with the vehicle, most of it minor stuff that wouldn't bother me (frozen drivers side door look, inoperable passenger side power window, etc). However, one thing became apparently evident in my conversations with him; being a 50-something year-old CPA from Guam, he knew diddly squat (I'm censoring myself here) about maintenance and how vehicles work. Sure enough, I had just driven into down and happened to walk by the drivers-side door when I caught a slight whiff of old oil. I drove home, inspected the underside of the vehicle, and sure enough it was slicked down pretty good. Not with new, viscous oil (whew), but with old, gunky, dirty build-up. I'm guessing that this 'cruiser has had a slow leak for years that hasn't been addressed (which doesn't make sense, was serviced at the dealership just last month). Any ideas on where this slow leak might be coming from? FWIW, engine bay was dry, it was the underside that is wet. Also, if you are looking at the vehicle from the front, the right side was dry; left side was wet. Thanks in advance.
Edit: Checked the oil. Oil level is fine. Also when driving, temp is fine, oil pressure is fine.
Toyota spec allows for up to 1 quart per 1k miles to be used.
Without pics, it sounds pretty typical.
Gotcha. Used as in burned, used as in leaked, or both?
Unfortunately, I just spent the better part of a half hour scraping the sludge off with a dish scrubby, so right now it would be pointless for me to take pics:bang:
If it leave spots, I would be bothered by it. Other than that, being anal about little leaks is going to give you an aneurysm.
Pressure wash it at a DIY car wash or a pressure washer if you have one. Dont get too close to anything though.
x2. If it is a simple fix (ie. distributor o-ring), you can fix it, but if it is an oil pan (alot of work, or money if a shop is doing it), and it is not dripping on the driveway, I wouldn't worry about it. You might use an extra $5 in oil a year, and there is no harm being done.
Thanks. Any chance it could be a corroded oil line? I'm not very familiar with the 80 yet and I don't know what to look for. Hopefully I can powerwash or scrub all the gunk off the bottom of the chassis which would give me a clearer picture of where the leak would be coming from. Right now there is so much old buildup and gunk under there, it's too hard to trace the leak back to the original source.
My main leak was coming from the oil pan and was remedied by re-torquing the bolts to factory spec.
Pretty sure it isn't the pan. This leak seems to be originating from higher up than that.
I re-torqued my valve cover and my leak slowed down significantly. If you do so, DO NOT use a 1/2" torque wrench. Use one designed for inch pounds. I have read that the bolts can twist off and some of them are next to impossible to get out with the engine in the vehicle.
If it is coming from the top then most likely valve cover. However driver side leak could also be power steering leaking out.
O ring for distributor. Oil Filter???
1/2"? Don't most non-american vehicles use metric size? (my maxima does, hey, I'm new to this 'cruiser thing). Just double-checking. I don't want to start wrenching stuff before I know what I'm doing.
Man, I need someone to send me a picture diagram, lol. I'll go check the valve cover now, that's simple enough. Couldn't hurt. Where would I find the distributor? (embarrassed).
Edit: I think I'm getting closer to isolating the leak. I'll try and get some pics up here for you experts to analyze.
I think he means 1/2" drive.
The socket itself will be a metric size. The moral of the story is to be gentle with them, they take very little force.
Okay, here are a couple of pics. I apologize in advance for the large size and the amateur labeling job.
Check the "push rod cover". It will be on the passenger side of the block, behind the distributor. I think it has 12 bolts. Chances are this gasket has never been replaced.
HTH
Edit- The pics you posted are of the push rod cover. Your label "wet" is covering one of the push rod cover bolts. Replace the gasket and you should be good.
You could also try tightening the bolts (gently!) as a stopgap measure.
Excellent, thank you. How much is one of these gaskets gonna run me? How much time should I set aside for an install?
Just attempted to do that. I could barely fit a ratchet down there with all the hoses and s*** in the way, never mind get into a position to actually turn the bolts. It looks like I would have to remove a gangload of tubing and hoses just to turn the bolts. I am not a happy camper right now.
Forget the ratchet. Go buy yourself a set of racheting box end wrenches.
If it's not leaving oil spots, then don't screw with it. I don't know how many miles your rig has, but mine had 164K when I got it a couple months ago. I know it's never had a power washing it's whole life, because I knew the PO. It's been nasty as hell doing my baselining and I can't tell you how many times I've pulled the steam cleaner/power washer out, but it's getting better. I still havent seen a oil spot on my cement, and after a couple thousand miles I can't even see a lowering on the dipstick.
