Lights work half the time
Ellicott City Md
Hey everyone, hoping some of you know how to fix these problems. I've had my 92 land cruiser for about 3, it's never been in its prime but continues to run strong :steer:
But just recently there seems to be shortage in places like...
The gear lights on the shift work when they want)
The check engine light doesn't work (I only noticed this because I removed the cat and it didn't come on)
Cruise control light will randomly turn up (it never actually worked though)
Hope some of you know the solutions :)
You only need lights to work half the time, right? at night?
Check the wiring on your, uh, are we calling it park/neutral switch? neutral safety switch? The pie shaped thing on the side of your transmission what lights up the gear selector lights on the dash. If it's just the D light that doesn't work, that's a burnt out lightbulb.
The way to know if your check engine light works is if it turns on when you turn the key. If there is no trouble it should then turn off. And like inkpot said - on obd1 vehicles there is no catalyst efficiency sensor that would notice whether or not your catalyst works.
Cruise control not working could be connected to the first thing i mentioned - the switch on the side of the trans. Also bad grounding to the trans. Also the cruise ecu.
Thanks guys! I didn't know about the switch on the train so I'll take a look at that. The check engine light used to light up on acc, not sure how long it hasn't been working, I just seem to notice recently
