Lightning Strike Aftermath
Dunnellon, Florida
I had a power anomaly of some sort that I believe to have been a result of lightning strike last summer. It was powerful enough to short out my ECU/ECM to the point that it had to be replaced. After this event I had fuses popping like popcorn. I spend the last three months tracing wires and found shorts in the TVSS security system wiring that I disconnected and uninstalled. I also found a short in the power antenna that I am sure was a previous problem since no antenna was installed on the truck when I bought it. Also the most disturbing one is the the short that comes with the 10 amp ECU-B leads and fuse. It seems that the left low beam head light plug was melted. I replaced it with one from a Camry. I also replaced all the fusible links and relays for AM1 and AM2.
Now here is the frustrating part. I turn on the key and and no start. I have no warning lights on the dash and and if I try shift the transmission into neutral and was unable to. for now these are the two main issues. Is there some sort of reset, sensor, relay that I've missed? I was told when I bought the ECU that was refurbished and reprogrammed that I would may need to take the vehicle into Toyota to have the security recoded or deleted. I confirmed this with Toyota who echoed the sentiment.
That would be a useful talent.
Reason # 735 why I don't live on Flo Rida . So back to the important stuff, what year do you have ??, because some have several ECU's for all kinds of things, Like the transmission, Cruise control door locks security ( located under drivers seat)
It's a 1997 40th Anniversary Edition. I looked at all the all the ECUs and even had the complete dash off at one time. The puzzling part is that the only electronics that are currently working are emergency flashers, but not the turn signals, headlights, horn and interior door lights, no dome lights. Prior to me replacing the fusible link and fixing the shorts the turn signals, radio and such worked. I was having a constant short in ECU-B (SRS System) and ECU-IG Headlamps. However, the transmission will not move out of part to neutral. I am considering pulling the dash back off and rechecking leads, relays and connectors. Any help is much appreciated
I'm not an electrical engineer but if you have a short in the SRS wouldn't that disable the vehicle entirely?
LS1FJ40, I found no short in the SRS, but I did find one in the cruise control actuator under the hood on the right side. Both are fed by by the ECU-IG fuse. I have been reading about the shift lock ECU. I will look at this tomorrow. so far what I can tell it immobilizes the vehicle
Kind of an update, I had to take My wife's Tacoma to the dealership today. I plan to pose the question about the SRS possibly being faulty or possibly short. I'll let y'all know what I find out about the Rhino. On the Tacoma it seems is a combination of tire damaged when put on by the dealer and a bad rim. Luckily I have a new rim at my house.
