Lighter socket shorted, now no tunes
OKLAHOMA cITY
I plugged in an inverter that my son wired backwards.
It knocked out my stereo and my clock.
I checked the fuses under the dash to the left of the steering wheeel. And I checked the fuse box on the left side of the engine compartment. None of the fuses where blown. But still no stereo.
Is there something else I should check?
Thabks
I highly doubt it burned the wire and not the fuse, but it is possible.
Find the Fuse spot that runs the radio and see if you have power on one side.
Then start tracing the wire.
Aftermarket radio? If so they may have placed a fuse on the backside of the radio.
Aftermarket radio? Like said by @Mudder there might be a fuse behind the aftermarket radio. Does the clock work now? Does the dome light work does the cigarette lighter socket work? Sound s like a blown fuse to me if a wire got burnt up you should smell it.
Shot in the dark, but might want to check your fusible links as well (attached to positive battery terminal).
Even if the aftermarket stereo is fused, that wouldn't explain the clock not working. I know you checked all the fuses and they looked fine, but maybe try replacing each with a new fuse as a quick, easy test?
I hate to report this, but I just bone headed this whole thing.
It did blow out the stereo fuse, but barely a break, and was a cloudy fuse, and didn't see it!
I switched fuses to be sure, and it turned back on!
Thanks for all the help though!
Doesn't the cig ligther have a fuse as well on the back of it. Can't recall if that just effects the cig however.
Check fuses for Continuity with a multi-meter. Its best method.
A fuse can look fine sometimes & be blown - atc's are funny like that.
Maybe a fusible link?
Yes, but only affects the cig lighter. You can take it apart and bypass the "fuse" easily enough if it ever does blow. Any time I've used an air compressor in the cig lighter it's blown this one.
