Light Modifications - For FAQ
Lndcruz's and others inspired me to go a similar project, heres the thread with all the info you will need
https://forum.ih8mud.com/80-series-tech/415588-bi-xenon-retro-fit-simplified.html
I'm not that bright (pun might've been intended) when it comes to cars...do you have a thread detailing where you got the retrofit gear from and/or the process for install?
Is it as easy as just ordering the housing and projectors and then swapping out the OEM setup? (do you need a new connector to plug the projectors into?).
Thx
I got all my gear from The Retrofit Source online: headlight upgrades for all applications
First you need depo lights, they pop up every once in a while on ebay. If your not comfortable cutting and drilling headlamps you will want to follow Chef J's thread. He used morimoto projectors which are essentially plug in and play projectors. The fx-r's require you to cut out the back side of the halogen reflector.
https://forum.ih8mud.com/80-series-tech/398120-another-projector-retrofit-into-depos.html
How do you remove the auxiliary light panel? I’m reluctant to go prying on 25 year old plastic….
