We did a side pull on a rock to clear a trail this weekend. It kind of screwed up the tree save we used on the rock. I was thinking that one those cheap lifting straps from Harbor Freight would come in handy for stuff like that.
Actually I was thinking the HF straps were cheap enough to be disposable so you wouldn't worry if they got damaged by a rough rock. Otherwise why not just screw up your tree saver.
Try to get your hands on a used bit of fire hose and use that as a protection.
That's a good idea, I have friends that are fire fighters so it would be doable.Try to get your hands on a used bit of fire hose and use that as a protection.
Or simply get a chain to move rocks and stuff.
I don't think it's correct to say that a wire rope cable would not flay around much if something lets go suddenly, unlike recovery straps. It may not appear "stretchy" but it will store energy that has to go someplace, likely into kinetic energy. The more tension the more energy of course.
How is that kinetic energy distributed?
First, I always over kill. IOW if the rock looked to weigh 200# I'd use a 500# strap. I'd probably get the 1000# straps, any rock bigger than 500# and I doubt I'd try to winch it off the trail anyway, dragging that much dead weight with a winch would be difficult.
Second, unlike a recovery strap that is intended to stretch and recover the cables and straps used in winching really don't flay around all that much when stuff breaks or slips. Specially when it is a relatively light object ie not a truck. BTDT.
This 3" strap they sell looks pretty beefy to me...
http://www.harborfreight.com/3-inch-x-30-ft-heavy-duty-recovery-strap-67230.html
