Liftgate Emblem Removal
Tried fitting my OEM ladder the other day. Looks like I need to move some emblems including the big Land Cruiser on the lift gate. LX suggested dental floss. Looking for suggestions on removal and reapplying them. Thanks.
They have little posts on the back and are adhered.
Floss is not a bad idea...fishing line (high test) works too.
Heat the area up with a heat gun or hair dryer on high. Then follow that with the dental floss/ fishing line. You'll likely have some residual 'goo' which can be removed with goo be gone or I like to use Isopropyl alchohol.
If it's gonna take heat I might have to wait until it warms up a bit. Pretty cold around here now. Thanks.
I did badge delete on my 80. The toyota emblem has two posts and you need to remove tailgate trim to get to the locking nuts on the backside otherwise you will snap the posts. The "full time 4wd" is a sticker and can be removed with a credit card and/or heat gun and/or hair dryer. Clean up the residue with some denatured alcohol.
HTH
ST
