I'm no expert at all on this category and I could have camber VS caster and all of my terms mixed up here....BUT I went through this recently and alignment tech + mud members explained to me that with a lift you can only get so much adjustment out of the stock setup.. upper control arms needs to be replaced with aftermarket once lifted beyond a certain point to be able to get full adjustment on alignment rack
>> Someone correct me if I'm wrong here.
How lifted are you? measure from center of hub cap to fender lip. Over 22"?
What does this mean? Doesn't that mean alignment print out was good to go but you just think visually it looks bad?
>> My mechanic said that when the alignment was done after the new tires, all ranges were green.
