I have an 09 with OME lift, OME UCAs, OEM 18x8 +60 wheels, 3/4 spacers (taking offset to +41), and 275/70R18 tires. The 1" KDSS max relocation kit has also been installed. At this point I have very minor rubbing on the inner most part of the front fender liners (drivers side when turned right and passenger when left).
Front hub to fender: 22
Current alignment spec (most recent one I have anyway)
Camber L -.2 Camber R 0
Caster L +3 Caster R +3
Toe L +.14 Toe R +.14
If I add more caster, is that going to increase the rubbing at the front? Should I have some removed? Or leave it at 3 and massage the liners?
I am going to ask for camber to be -.1 on both sides and ask for toe to be reduced to .06 on both sides.
