Lift Question
NE Texas
A few weeks ago while researching upgrades for my new toy (97 FZJ80) I found a site that sells lifts with 2" springs in the front and 1" lift in the rear to remove the "stink bug" effect with most lifts. I am not sure what brand springs they were but now I can not find the site? Anyone ever seen this set-up? I am going to convert to a diesel which is about 200 pounds heavier than stock so I think I will go with heavy front springs and probably medium of soft rear to keep it's stance level. The only problem would be if I add another tank in the rear then I might need the heavy rears. How do the heavy springs ride unloaded in case I decide to go that route?
Thanks - Rusty
97 FZJ80
78 FJ40
I think you're better off going with one of the proven spring sets. OME makes enough that you should be able to pick out a combination that gives you the rake and lifet that you want.
T.
Any ARB vendor should be able to sell you whichever combination of front/rear OME springs that you want. Cruiser Outfitters and Slee Off road come to mind...
That's the one, thanks!
Rusty
97 FZJ80
