lift kit
Nope not according to Slee.
"When you measure the traditional "2 Degree" bushings from Old Man Emu, you will also see that they actually correct closer to 3.3 degrees. So they are still the correct adjustment for a 2"-2.5" lift."
I think we need to add some explanation to the above. When I mentioned that it measures 3.3 degrees, that is when you draw out on a flat piece of paper the amount that the bushings will rotate the axle if installed per OME instructions. However from experience we do not see that number on an alignment rack when you take pre and post measurements. With the OME bushings we see 2 degrees as measured on the alignment rack. I have never been able to find out why the measurement is not the same, but it has to do that caster is measured a sweep between steering stops and not a simple axle rotation.
When the 80 is lifted we have also seen approx 1 degree of caster change (as measured on a rack) for every 1" of lift (in the 2-4" lift range.
Now if one uses a 2.5" list (which OME lists as a 50mm lift ~ 2") correctly, one would get about a 2 degree of change and the bushings will correct for that. But, if heavy springs are used with no load , you normally net more than 2" of lift and the change will be more, so the OME bushings are not enough.
I'll have to agree with Landtank. I installed the 850/860 springs with the OME yellow caster bushings and my rig wandered all over the place.
How much lift did you get out of the 850's? What load do you have on the front.
I replaced the bushings with Slee's blues and there was noticeable improvement. My alignment showed I am at minimum spec, still not as good as stock....as far as driving it goes but what do you expect when you lift your rig? :D
If your lift was more than 2", then yes, the blue's will give more caster and drive ability.
While OME supplies their caster bushings to all their kits they actually only fix the caster issue for their "no lift or stock height" springs. Using any other spring they offer and your caster will be low and the truck will feel it.
This might be your opinion and experience, however when we install the OME Kits as recommended with the weight on it as required to yield the right amount of lift, we get the correct caster change with the bushings. So to say that it only corrects for stock height replacements is simply not correct.
We have also verified this by numerous installs and pre and post caster measurements.
I will give you that a lot of these trucks are low on caster to start with, and could do with more when lifted.
Immediately after install, I had almost 2 3/4" all the way around. Since driving it though, I have not rechecked, but I'm sure it settled in a bit......also, no weight on the front yet (bumper in the future) and wanted the level stance.
that's the thing right there, most of the people that I've work with are not loading the trucks down with the additional weight. There first mods are springs and tires and the result is taller than OME specs which results in low caster and for some an unacceptable handling truck.
And as soon as they start adding the weight they compensate for that with spacers. Now this might not be what your customers are doing but it's what I've observed here on this board.
If they are going to buy product and then pay somebody to install it, it might as well be what the truck needs.
Just my opinion and I'm only trying to save people some time and money and help them get the truck they want.
So the correct thing would be to say that they do work for a 2" lift, but if you put a 2" heavy lift on a truck with no load, and you net 3"+ of lift, the bushings will not be enough.
However to say they do not work for a 2"/2.5" lift is not correct.
Yes, that might be true, and in those cases they need more caster, but people will read what you wrote and then take from it that the bushings don't work for a 2" lift, when in fact they do.
what ever
Part of this discussion seems like the age old what CC solution should I use. I learned over time to just say measure decide, re-measure... and go from there YMMV :D
