Lift install
I'm too far to help. But, I can tell you that getting a spring compressor might be worth your while. I rented one and it was very handy.
Wish I could help. I'm not too far but have no time and not the best place to work on a rig. I just put on a 3" Dobinsons and see no need for spring compressor. With the shocks and sway bar disconnected, you should be able to pop out the old and put in the new. Good write up on Slee's site for install.
Slee - OME Suspension Installation (Toyota 80 Series Land Cruiser)
Also, take your time taking off the rear shocks. You create lots more work if you bust off a bolt.
You may want/need a spring compressor IF you cannot jack the rig way up in the air, set the frame on tall ( 6 ton? ) jackstands, pull the wheels, unbolt the shocks and misc. bits like brake lines, and droop the axles enuff to release the stock springs and insert the longer lift springs.
Only start one thread at a time for the same request.
