Hard side pulls w/ synthetic line can warp the side guides of the drum. (replaced, and no questions asked).
Never use those lame delrin rollers designed to replace steel rollers for use with synthetic line. A side pull will cut right through that stuff.
Use the snatch block. It saves the winch, and your line.
You should load your synthetic line under a decent load to prevent the line from trapping itself on the drum.
Read about synthetic line use before using it on your winch.
