gosh Pablo, I could not venture to attempt to measure the stock fans output in CFM..........I do know that as is listed in the SPAL USA site; this type of electric "pancake" fans is a favorite of racers and rodders; have been very happy using them over the years; and what I like most is that they are not draining HP except when needed an addition to taking a load off the water pump bearings...........think Toyota addressed this when they went to a fan clutch in the later 2F motors; just rule of thumb IMO just stick in the largest capacity "CFM" electric fan you can afford or stuff; puller would be best as it is more efficient but I only have only had space for pushers at times so have had to go that route 3 times in the past once in a vehicle with a (GENERATOR) 28 amp. max out put!!....no problems now after about 8 years........the best would be a puller/pusher combo..........if your electics can handle the amps.........I would think that the standard toyota alt. would handle it as there are not a lot of electric needs on our cruisers....you have the amp pull of the fan motors listed on the SPAL website..........I have never installed a SPAL having used most recently Pro Series "WYSCO 16 INCH SUPER HIGH OUTPUT THIN LINE SERIES ELECTRIC FAN" reversable-pusher-pullers; the amp drain on these are listed as a max of 12Amp............ hope this is of help
Lou
Lou
