Parting Out Lehi, Utah ***Updated 93-97 FJ80's and LX450
No outer fenders left. I have the inner ones though. No Y pipes left, but I do have a few manifolds if you want one. (Front and rear.) As for the transmission mount.. Are you talking about the one that is underneath the transmission, that bolts onto the support brace? I have a few of those.
Sorry for the late response, just been busy.
-Fin
Hi,
Do you still have the driver's side inner fender?
Thanks,
Henry
Nah, the old brain wasn’t connected as I was typing.
Meant oil pressure gauge. Sender unit and wiring tests fine but seems to be a short or failure in the gauge itself in the dash assembly
No worries! Just depends on which year your cruiser is. I have one cluster I am parting out that is a '95 I believe.
Hi,
Thanks,
Henry
I should. Where are you located?
Hello,
do you have available: The transmission cooler, hardline junction for ATF hoses thru rad support, and the hoses to and from trans cooler and hardline junction?
Thanks!
LX450 Fender flares?
I need both latches out of the lower tail gate if you have them . Could use the handle as well
price shipped to 85373 please .
I do not have any in stock at this time.
Do you have blueish/gray door cards for an 80?
Unfortunately we do not.
How much for driver side lock cylinder to fit a 1995. Shipped to California.
PM sent.
Hello,
Thanks!
I should be able to come up with everything. Send me a PM and I will get you photos of what we have.
1993 console lid available?
I have one left that is brown. $80 + shipping
Which side?
White fzj80 driver door and white rear hatch.
Thank you
Tommy
I don't have any clean ones left in white, sorry!
Any chance you have a wiring harness you would be willing to cut two connectors off for the ABS pump module? Need the wiring harness side plugs (1 black and 1 gray).
near the master cylinder:
To be correct, you need the pigtails that the blue arrows are pointing to?
I should have a harness for cuts, I will check for those two.
