Parting Out LEHI, UTAH 1977 FJ40 - FOR USED PARTS!!!
my guess would be that it meets the federal standard prior to the new 1977 clean air act ammendments.
which probably were enacted by 79 which is when they started putting them in.
so non catalyst. non catalytic converter.
had to designate who knows?
I could be wrong on mine though. The motor at one point was equipped with a smog pump because the bracket is still there, but pump deleted . Here is the tag on this rig.
Front axle with disc brake calipers, bolts, brackets and front brake lines.
Hub to hub =$400. Selling the rear axle in pieces... rear diff. $200, left axle shaft w/backing plate $75, right shaft with backing plate $75. Rear axle housing $150.
$23 on standard ups. It will also come with all the hoses and clamps that mount to it, as I fear that if try to remove them- I may break a port.
Those Warn or Asco locking Hubs?
Have the gas door with the lock, key, screws and catch latch?
Here are the front heater parts. Heater assy needs some love, the lever does not move. Heater core seems good, I put my finger on one side and blew on the other, and it held pressure without leaking. Small crack on left defrost defuser and on the bottom of main air duct as pointed out by the orange arrows.
Fan blade $30. Fan shroud $75. Coolant resevoir with bracket (needs weld), cap and hose bracket $30. Radiator support $100. Radiator support rod with bushing and nut $30. Radiator brackets also available (not shown)
about this gas door catch & screws?
dscn3126-jpg.2369687
