Left rear hard lean
Fort Worth TX
I have the 863 in the rear but I have a 20lb co2 tank mounted over the left rear tire. A rear spare wheel/tire mounted on the left. My tool box and the gas tank is also on the left. So this all causes the truck to be over an inch shorter on the left rear.
I have a pair of 863j springs as well. They were replaced with the 863 due to the stink bug look.
Can and should I just swap out the left rear spring for the 863j to level it out?
I will throw in this thought.. Why not level out the load in the rear? Not only will this fix your sagging issue, but it will also help handling characteristics.
The two rear springs will be different heights short goes on the non gas tank side long one goes to the driver side or gas tank side
Ya, going to say better weight distribution here. Different spring ain't going to help that. If un-avoidable then trim packer/spacers. But 2" is a lot. IMHO.
They look the same but tools is right. One is longer in all the oem spring variants. Its designed to compensate for driver and gas tank weight.
As far as the question of any reason not to run different springs dirtdawg nailed my concern of handling characteristics. Soft left turns and firm right turns come to mind or vice versa. Might not be an issue if the spring rate were the same but 'believe' there is a difference between those two.
Put a tape measure on it and see the actual difference. Common mistake of swapped springs nets about a 1" side to side difference.
Ok so I swapped the spare tire and hi-lift sides on the rear bumper and it helped out a lot. There's about a 3/4" gap difference now. I didn't install the lift, the previous owner did so idk if the springs were installed correctly. I didn't know there were different height springs for driver and passenger. How much of a height differ is there?
Spring rates are exactly the same 44 N/mm
From the FAQ on this forum.
So maybe use the short spring in the 863j pair?
Cool. I couldnt recall and our OCD spring expert @GW Nugget hasnt chimed in yet :D
I would be tempted to pull whats in there first and see if they are correctly oriented. You made a noticeable improvement with just weight relocating.... now time to see if it was installed right before adding a band-aid. And thats coming from the band-aid man
Ya I'll check the springs and if they are in fact correct, I will swap in the shorter J spring and see where it's at.
I'm also looking at running 37s but not sure if that's the best option for the crazy terrain I do and for the longevity of the parts due to the extra weight.
This truck just swallows 35s and they look almost like stock sized tires. Lol
Agree these things swallow tires. I ran 37s for 5-6 years without issue and went back to 35s this year mostly for a cross country trip on stock gears.
Wheel smart and shouldnt be to big a problem.
Ya 35s are just the best all around size. I don't know there is too much to gain going 37s other than actually looking like a bigger tire.
I drive the truck all over. Driving to Colorado in January for a week trip to drive through the mountains and snow trails.
Hitting slaughterhouse gulch and Chinaman gulch
Ok so the springs we're on the correct sides so what I did was take the shorter spring of the J spring and put it on the driver rear. That made things pretty much even. Maybe 1/4" at most, if that difference now.
