LED bulb replacement question
mulebarn
GOLD Star
Boulder County, Co
Hey everyone,
I am considering changing out my HZJ73 headlights for the Rigid truck lite LED headlights. Also, it would be great to replace all of these light bulbs with LED bulbs in the blinkers, reverse lights, and so on. Has anyone done this, and what should I be aware of? This is a 24v truck.
Thanks.
i have been very happy with Oddirons LED solution, if you are open to another source.
I have been very happy with both interior and all exterior LEDS.
Thanks, I’ll take a look. I emailed Rob to make sure they’ll work in my 24v truck.
Most LED bulbs will work up to, I think, 30 volts? So the same bulbs can often be used in a 12v or 24v truck without issue. (I do not think that includes headlights.) Mine from Superbrightled.com are 10 to 30V DC
Just replaced my rear turn signal lights with LEDs. Got hyper flash (lower resistance of LEDs causes turn signals to flash much quicker). Ordered a LED flasher relay from Odd Iron. Installed it a few days ago and back to normal. My truck is 24V. Odd iron has everything needed to convert over a 24V truck.
You can "see" and "be seen". :)
