leaking injectors
hillbilly desert rat
After I installed the fuel rail the injectors are leaking I only replaced one of them. that one is not leaking. I replaced the Orings with new ones, only #3 and #4 are leaking. Any helpful hints as to how to remedy this situation?
D
I lube them up with engine oil when I install them, that's about the only trick I know...
Ditto that one, I always just put a little 30 weight on my finger and grab the o-ring and it'll slide right on w/o pinching, nicking, or tearing it.
try to clean your fuel rail. I had a similar issue when building my friends 4runner. I ended up getting some aftermarket o-rings and i cleaned the hole in the rail with a pipe cleaner and it has not leaked since. we went through 2 or 3 orings on number 4 before that.
