leaking brake fluid??
So i found out that the leak in the brakes is coming out somewhere where the brake pedal goes through the firewall. Brake fluid leaked all over the area where the pedals are. A rubber peice was broken somewhere up on the brake pedal. If anyone has any ideas what is broken/missing, it would help me save a lot of time and money..
thanks
Blake
thanks
Blake
Master cylinder is shot. Rebuild or replace.
I don't think an SOA will help... :D
Kirk
did we not cover this a couple weeks ago???
You will need a new brake master cylinder and odds on, and new clutch master and slave cylinder.
I would think long and hard about upgrading the master to a dual circut set up, especially since you are set on a SOA. ;)
Good luck!
-Steve
Have you EVER been HERE ?
Has been used as a baseline for pricing things for YEARS.
Oh, and you must have missed the ;) about your SOA.
I would still look at upgrading the brake system to a dual circut set up, even if you stay with drum brakes for some reason. :rolleyes:
Good luck!
-Steve
McClaskey said:
i know but i think its just one little rubber peice on the cylinder...
No.
That little rubber piece is nothing more than a dust boot. The internal seals in your master cylinder are shot.
As others said, this is prime time to upgrade.
It would be nice to upgrade to a dual cyl master. If your keeping her stock the OEM metal canister ones are still available from the dealer or you can get the later (early 70's) with the plastic cup and rubber cap
If you loose a line/hose etc. on the front or rear circut on a single system, you will loose your brakes completly.
If you loose a line/hose etc. on a dual system, it only effects the circut that the failure is in, and you will still have one that works.
Good luck!
-Steve
McClaskey said:
Ohhh i see, lol that seems a little bit safer...
I lost my brakes about a mile from home a couple months ago on my single master 9/64. It was indeed interesting driving home without them, going up and down hills and around corners, then down into the barn. :eek: :D
Actually, I think I got the last one. Or, at least, that was what I was led to believe. The plastic reservoir ones are better because you can see the brake fluid level, and the duals are better yet, in all honesty, for safety. But you will also need an adaptor if you are going dual, because of the firewall brace. Mark of Marksoffroad has them. Then you may have to deal with space considerations.
McClaskey said:
how much is a new master cylinder???
Check your local NAPA i got mine pretty cheap it was a rebuilt Japanese
I believe it was $58
